South Central Kansas, Harper County | This was on a 262 receiver, and come to find out, I have lost power to the receiver. No light is showing in the bulb on the back. Talked with a gps tech on phone Fri afternoon, he had me check the nav II Controller to see if indicator light was on, which it was. Told me it is on same circuit/ fuse that receiver is on, so a blown fuse couldn't be the problem. Told me it is probably the receiver, and they can be repaired at ag express, if I elected to go that route.
Back to the 262, shouldn't I be able to take my volt meter and check voltage at the plug? Are the bolts on top of cab on my case/IH 3320, an adequate ground? There are 6 wires going to receiver plug. , orange,black,green,yellow, red, and red with white stripe. Which would be the hot one? How many volts are going to the receiver? Looks like I need a paperclip or something similar to access the pins inside the plu, unless I strip the wires on other side of plug? Any guidance or opinion is greatly appreciated.
Thanks, Jim |
