Maryland | Just put the Carlisle wt300's on. Man, what a difference! Now I can pull straight down a hill and not worry about if I can back up. Basically it can go anywhere and do everything it should do. I think if you watch the tires while turning, you don't tear anything up at all. With the turf tires, every time I turned around the tires would spin and tear things up, basically no traction for a lot of hills especially if slightest bit wet. The last picture, you can't really see how steep it is, (it is tip-over steep) but before I could only make 2 or 3 passes along the top before I had to go up and down. This time went at a 45 degree down the hill after a rain and it held! Highly recommend!
Edited by graystonefarms 6/7/2015 07:14
(kubota1.jpg)
(kubota2.jpg)
(kubota3.jpg)
Attachments ---------------- kubota1.jpg (130KB - 71 downloads) kubota2.jpg (160KB - 69 downloads) kubota3.jpg (100KB - 70 downloads)
