Posted 6/5/2015 06:57 (#4609743 - in reply to #4609458) Subject: RE: 4840 loses all hyd-shifting
With shavings in the hyd oil filter you have problems going on and they are only getting worse, the tractor needs to be shut down until you find the cause of the problem. Pull the hyd filters and cut them open ,I would bet there are alot more shavings at this point.
