Posted 6/4/2015 21:38 (#4609263 - in reply to #4609049) Subject: RE: Raven auto boom users
Brandon, SD
Stick your hand under the sensor at the ground and raise at 1ft per second, boom should follow at that speed. When you stop moving your hand it should stop moving within a foot. Adjust your speed setting until you achieve this. Sensitivity I like to set so if I quickly kick my foot under the sensor it just barely twitches the boom, this will be crop dependent though.
