Posted 5/26/2015 12:56 (#4592061 - in reply to #4591765) Subject: RE: Paradyme, Integra, JD R series ISO steering Problem
Central Nebraska
Have had the same issue with several JD's using ISO. Seems to be worse on the tractors with front duals. Have not found a solution for this. Have been through the same steps with Ag Leader as you have described, with the same results. May be the nature of the beast.
