southern MN | Have you tried any of the simple basic stuff yet? I copy and pasted this, what it would try first, they wrote it better than I would say it (other than closing apps, donno how you do that when its not functioning!), but generally recharge it and then the various resetting options:
Paul
It may be a battery related issue. Just connect your device to a power outlet and wait several minutes.
Some particular apps may be causing the problem. Try completely closing all apps and restarting your device.
This problem may occur if your device is operated under extreme temperature conditions (like being too hot). Simply place your device in a cool area for several hours to let your device to cool down.
Try performing a simple restart of your device (press and hold the sleep/wake button until you see the “slide to power off). If this still does not resolve your issue, try to reset by holding the sleep/wake button and home button together for at least ten seconds (ignore the red slider).
Last resort: Restore your device in iTunes by connecting your device to your computer.
