SE MN | I can answer a couple for you.
-I would put it in every row. I agree with above poster that you only need every other row, but just in case a row gets plugged or something, it won't be a disaster. Most I think are sold as every row.
-Get it on when weather permits and you have time. If you are done with spring work, the ground is fit, and the corn is at V1, put it on! Nothing worse than waiting till V6 or V7 and it's too wet. Then you are too late to the game after that | |
