Posted 2/27/2015 17:45 (#4418966 - in reply to #4418949) Subject: RE: Anyone treat their own seed w/insecticide
IA
1250 is a pain to apply. To do it accurately you put a lot on and it gums up the treater systems with lots of buildup. Unless you have a Teflon coated treater I would advise against it. If you do do it flush your lines out with hot water after you run 1250. I've only seen it in 250 gallon totes, can you get it in smaller jugs?
