Posted 1/30/2015 22:25 (#4351136 - in reply to #4350149) Subject: RE: EZPilot on 6175 White
If the splines are the same as my 6144 then a kit for a JD 4450 will work. The inside if the anti rotation bracket needs to be ground out a little to fit over the column.
