roaming | JREZ - 1/26/2015 07:33
Hey we are new to all of the technology for the most part, I was curious as if we could hook the pro 600 hundred to show our tractors data on it. We have a 2008 magnum 245. And if so how would we go about doing it? Thank you for all the help.
Yes. If your tractor does not already have the display harness, you'll need to get one from your dealer. It plugs in in the right rear pillar. You'll also need your dealer to load the correct software into the display. And you'll need to tell the A-Post that the display is installed. Your dealer can help you with this, or you can look in your operators manual.
You will also need to make sure that the tractor controllers are loaded with software that is compatible with the Pro 600. |
