Posted 12/15/2014 12:55 (#4241783 - in reply to #4241700) Subject: RE: MX Autopilot troubleshooting
North Central IN
Assuming this is an aftermarket install with steering valve on back. First check to see if spools work. Insert an allen wrench or similar item you can push into each end of the spool. This will manually turn the wheels. The spool may be stuck. Had this happen on a similar tractor this summer.
