| Install it without any networking first, to check if the core Windows XP setup works. You can always add networking later. Besides, you probably can't install networking if yoou removed the network card, unless you have built-in networking on the motherboard and it's enabled in the computer's BIOS settings, the screen that you can get when you boot up the computer and press a certain key, like Del or Esc or a function key usually mentioned at startup. | |
