Morris, IL | If your running section valves, you only really need one standard valve on the Raven. The section valves will act as the on off valve. You just need to run high pressure hose or steel pipe between them. Take a look at our NH3 bar, just setup last spring.
I really like the section valves out on the wings. Like i say i'd like to switch fast valve for a standard and leave it in hold on ends rather then close for better startups. But having valves out on wings right at manifold shut off really quick.
Edited by NEILFarmer 11/28/2014 21:44
(IMG_0731.jpg)
(IMG_0672.JPG)
Attachments ---------------- IMG_0731.jpg (239KB - 126 downloads) IMG_0672.JPG (135KB - 131 downloads)
