S.E. Iowa | My son has a Farmall 95 with a 735 loader on it has 1300 hours. He has been really let down. Clutch at 700 hours, new injection pump and needs another one, lights didnt work when it came, two rear wheel seals, turbo charger, leaky valve cover, air conditioner, shuttle shifter at least 6 times (from bolts coming out to components failing), bolts came out of drabar, 5 or more bolts breaking on loader frame, total electrical failure, sticks at high idle intermitently, radio will quit for awhile and there is probably more. It has spent all total probably 3 months at the dealer in the 2 years he has owned it. The loader has had at least 5 sets of joystick cables they freeze up when it gets cold. It is about out of warranty he has told them he wants the extended waranty at just over 2000 dollars. He cant afford to trade but stiil needs a tractor. Is there any way to call someone and get some help on this? The main thing this has been used for is bale moving, hay mowing, more bale moving, some raking, more bale moving and the rest would be loader work around the farm which that mostly consists of bale moving:). {some days it seems like we just move bales for something to do} It is a great little tractor as far as size for what we use it for. Another positive thing about this tractor is comparing it to the two Masseys before it this is a home run.
Edited by farmer82 11/23/2014 21:37
