SE IL | Bear1062 - 11/22/2014 08:21
Using a 2013 1990ccs with Seed star 2 and 2630 screen. For some reason if I have the swath control checked on the 2630, the coverage map will not register that the openers are up and continue painting the map. I checked the implement switch and every things works fine when the swath control is unchecked.
I dont have any issues when crossing into a previous recorded area. Its only on the first pass like when doing my headlands first.
That's a head scratcher. All software up to date? Under planter, diagnostics does it show imp sw status changing both with and without swath checked? Has it worked previously? Recording source showing Auto? I had a 1990 once that got water in the relays on the left side of tank. Caused some strange things. |
