SC MN | Yes you can get by with having the access point at the house and having the office and bin site set up as clients. The only issue would be is if the type of access point you use would send out the proper shape signal that can reach both sites. Some access points have a rather directional antenna and some have an omni directional antenna. Usually the manufacturer will publish the dispersion pattern of its products. Call the manufacturers tech support people and they can suggest the correct product. | |
