SE North Dakota | Well after I replaced the $500 cable all the way back to the batteries cause I thought that was the problem. Then I looked at the ground strap right under the alternator that grounds the engine to the frame. Cleaned that up and has been working fine for two years. The bolt that screws into the engine wasn't real tight and you could see once I took the strap off how it had been arcing. 2008 435. Good luck | |
