NESD | Is there a way to test a ccm on a case 7120? Lower sieve and rear axle angle sensor keep going off driving me nuts. Looked on diagnostics and they are both part of ccm3. Dealer updated software. I triple checked/cleaned all connectors, cleaned all 7 ground points on combine, re-calibrated each sensor several times, replaced lower sieve actuator/sensor. No improvement. I would like to check ccm next if possible. Or any suggestions? The lower sieve out of position alarm I can live with but the autosteer making an immediate left while going down the field could turn into a tangle with the grain cart. | |
