thumb of mi | After I figured out the sensor was good. I put the psi on the run screen. The started engaging stuff to figure out which one was trouble. I figured it was the feeder drive. There is cvt, break and drive clutch sylnoids. I took each one off and engaged to see which one was the problem.
Ours was sealing rings on the shaft in the feeder clutch. 20$. But quite a pain to figure out on Sunday. Not to bad to fix | |
