Is the Terragator steering valve (often called a motor) stock? Standard valves are non-load reaction which means that the steering wheel does not move (or try to break your arm) when you hit a big bump off center with the front wheel. Non-load reaction steering systems do not need counter balance valves and the wheel will not turn when a auto steer system activates. The only Ag Chem chassis that I know of with a load reaction steering valve is the Ag Gator 1004. That was used to allow it follow rows. It would do exactly what you are describing. |
