NE South Dakota Clark, SD | I can't help you with the Deere side of your question. But I installed a Reichhardt TAC feeler system on a Claas chopper this fall. The machine was a few years old and did not have the factory valve. We used an EZ Steer motor which is how it was set up on his JD 6850 chopper prior to getting the Claas. We did not change any settings from the JD and he said it works even better on the Claas. His only complaint was that he sure missed it when he put the corn head on to do some earlage for a few days. |
