roaming | packerfan - 10/5/2014 19:47
Just WAAS and no guidance. Mostly level ground. I have purchased an older draper head with an offset throat. I wonder if the dealer had it set for that instead of the corn head? All 3 pieces are new to me this year.
WAAS with no guidance is probably the worst combo for Auto Cut Width. WAAS is a low-accuracy signal to start with, and then when you add the lack of terrain compensation (since you don't have a guidance system), you've got a machine that doesn't know exactly where it is, so Auto Cut Width may not be as accurate as you'd like. You can disable it if you want, and just manually adjust your cut width. |
