Posted 9/22/2014 23:33 (#4088759 - in reply to #4088695) Subject: RE: 9760 and fd70
Anamoose, ND
The voltage reading is out of range. When you calibrate hit CAL when you are down so the numbered indicator is at 4, then slowly raise the head up until the indicator is one number 1 before you hit CAL again. Seems to me you have to have the cutter bar about 3 ft off the ground when you hit the CAL button but the indicator needs to be on zero.
