Posted 9/19/2014 12:13 (#4082463 - in reply to #4082386) Subject: RE: Pro 700 and 262 receiver offline?
Minnesota
If you take the red plastic off under the rear window, you will find a 2 pin gray connector with a red and black wire. It is usually tucked in between the controllers towards the left side of the cab. this is your receiver power, I would check to see if this has been disconnected.
