| Go into settings/implement/application control/initial setup/ and select none. The implement icon is only for field iq setup for flow and application(rate and section control). Your implement set up is done when you open a field you will see implement set up. After you select none hit the green arrow or check and go back to your field. Your paint will start showing on the screen again.
If it doesn't check your coverage settings under guidance tab. | |
