Morris, IL | Yes on fitting in original housing. Assuming 1586 is same as a black stripe 1066, the old light will have two studs on back of them and wires from tractor attached to them. The LED from Larson lights had short wires on them already. I just spliced the wires and off i went. Housings were very clean when i took them apart, i figure they will stay that way. Make sure you get the right wire in the right place, they are sensitive which one is ground and which one is voltage | |
