Posted 8/27/2014 16:17 (#4041615 - in reply to #4041604) Subject: RE: JD 4020 clutch?
minndakot
do yu see that 1/2 bolt on the clutch pedal linkage... take a 3/4 wrench losen bolt tap with a hammer to slide bolt to rear of stop...you should have 3/8 inch of free play between stop and clutch pedal, if it still slips you will need a new clutch and about 1K worth of parts good luck
