Search Forums | Classifieds (67) | Skins | Language
Why won't my deck plate sensor numbers show in 9770?
crg530
Posted 9/2/2014 01:29 (#4051305 - in reply to #4046095)
Subject: RE: Why won't my deck plate sensor numbers show in 9770?
Northern CA
Header is a 1293. Thanks for replies. Using the header now every day and not fixed yet! Just run the deck plates completely closed because ther worn pretty bad. Still wish I had numbers. That's what I don't understand is if the combine can calibrate the sensor, it's obviously getting the ohm readings from the sensor...it's like it's a software problem on the combine because they worked on our 9760 and never has worked on our 9770...
