Fulda MN | If your header has single point hookup, would I be correct to assume this head was on a flagship combine with the splined shafts? I bought a 2062 last summer and put it on a 2388. It was setup for a flagship and needed to be adapted to make it work on a 2388. I have rear wheel assist as well and a third lift cylinder. It is heavy up there, but is no worse than our 8 row drago corn head. I would like weights or fluid in the tires to help keep rear of combine on the ground when I have to back up a slight incline as rear end gets light and rear wheels will free spin. If you need assistance adapting, I can assist you in letting you know all that you need.
