Posted 7/30/2014 05:33 (#3992759 - in reply to #3992737) Subject: RE: STS brake locking on. Help!!!
Lancaster, Pa
On the inside on the backing plate at the bottom there should be a rubber plug take that out. Than you will have to push the arm that holds the adjust back away so you can turn the adjuster with a screw driver. I don't remember which way to turn it I think up to release.
