Flora IL | I went to toolbox and nav then nema output settings.
My baud rate on the display is 38k so i choose that... for some reason my gga,avg or whatever is on 5. i had told it 10 tho on the pro now that i think about it. would that make it not show up at all on the cruizer...
i really thought with the baud rate's were the same that it would atleast see it. from the cruizer to the area where my fuse box's are halfway in between are two 9 pin's that say dgps and gps in to cruizer... so i have power to the 262 and ive connected it to the cable saying gps into cruizer.
Guess i'll try again tommorow and set the vga,agg to 5 and then i think the zda was on 1 mhz if i recall right. | |
