| I'm trying to locate the check valve for fuel on my 94 freightliner. I had a mechanic show me what to look for but every fitting I pull out nothing. Also the plate that my ECM is mounted too has fuel running through it. Fuel cooler? Is that iolsolated from the engine ground? I see plastic fitting around the bolts that hold cooler to the engine and some crosin. I also think I have a computer problem. Engine over heated due to a bad air sellonid on the clutch fan. Engine shut down. 3hr later got it going. stoped at a dealer. would not refire. mechanic ran it on either. said could be check valve cus I said it was taking a lot of cranking to start. then the pro scan could not read the computer. Bascily I'm cleaning all conections pos/neg plus I want to find this check valve! I found a little algae in last fuel filter change. Any input would be a great help
