central NE | I had a shutle with around 100 gallons that had set for maybe 5 days. and when I looked inside and looking thru the shuttle you could see that the Hales GT was separated out. I turned on the shuttle pump and let it run about 40 gallons and tryed to mix the contents but wasn't easy. I went to my supplier and picked up 2.5 as a back up just in case I run out. Returned it the next days and it also had seperated out also. They must of change the formula because it was not that way last year. The supplier said that that they have a return that goes back into the top of top of the tank, but say a 1000 or maybe a 2000 gallon tank tank will not get mixed very good. | |
