Posted 6/11/2014 13:17 (#3913620 - in reply to #3913154) Subject: RE: John Deere 9530 engine codes
ECU 412.03 = EGR temperature signal out of range High.
The input voltage exceeds the sensor range. This means the ECU thinks EGR temperature is lower then physically possible.
Measure resistance between terminal 1 and 2 on the EGR temp sensor. If more then 7.5 ohms the sensor is probably faulty. If not, then perhaps a problem with the wiring, connectors or ecu.
