| Can anyone give a hand. looking for a supplier that would have a 10,000 lb rated axle hub that would be a size to accept a tractor rim. 10 BOLT size.
Currently have narrow duals on a hardie sprayer and would like to have a single axle assembly on it. Easy to locate a 6in across tube but having a tough time
locating a hub axle assembly to fasten on the tube (weld) for a corect width axle. I do not want to cut up the exiting axle tube to make it work for this project because i have a use for the dual axle and wheels down the road. Would like to just install a 14.9 x 46 tire and rim assembly on my sprayer and go.
Thank you for any where to look. I know the local dealer just say's trade it in and get what you want but i like this one.
Gettin By | |
