Mid-Missouri | I believe I replaced my balls on the outer portion of the fold cylinders already. This is the location you are referring to I believe. IIRC, I bought some heavy grade 8 standard CAT bolts that barely fit to replace the slightly worn original Deere metric bolts. I also believe Lil Hoss said the ball is sold individually on the 4720 or 30 machine, and is likely were I got mine. I know some google searching for metric, female spherical rod ends would come up with what you need. | |
