Pto lever jumping outta gear so we checked the pressure on the ports on side of the pto valve body. Only 50 psi on the pto port at idle and up to 100 at full throttle. Clutch pressure at its port is 175 +/-5 across the speed range. How can pto pressure be low and clutch pressure in spec?
