ecmn | going off memory here.
put cardboard in front of radiator,
put in a jumper hose into one of the outlets.
set that outlet to continuous flow at about a 6-8 flow.
set another outlet with no hoses hooked up to it for continuous flow.
on the touch pad the right two buttons give you oil temp.
start tractor and engage both scv's and rev up engine.
once oil is at 150 degrees drive tractor around yard up to gear 13 for a couple seconds in each gear, and then do reverse.
open up fuse panel and install fuse into slot #10
use the right blinker to get to PCU, pull flasher back, get to address 20 I believe,
when you get to the right address you will see FWD in the corner display.
with engine at full throttle put lever in fwd and leave it there until it tells you REV. you will hear the engine lug down and the transmission changing gears.
I will look up the address's Monday.
Edited by easymoney 5/3/2014 14:08
