Posted 5/2/2014 19:12 (#3850438 - in reply to #3850374) Subject: RE: Cat 45 Hyd Problem
Walnut Grove MN USA
Try turning down the flow controls to the other valves. You should have the flow controls for the valves you are using turned down as low as you can too. I had the same problem running a sprayer that had a hyd driven pump plus constant flow to operate the booms. I think my 45 had been changed over to parallel from priority.
