Posted 4/28/2014 15:41 (#3841721 - in reply to #3841461) Subject: RE: CaseIH 5250 power beyond
I used to spray with a 5140. These Maxxums are not the best tractors to run hydraulic sprayer pumps. One pump runs EVERYTHING. Steering takes flow away, pushing in the "clutch" will interrupt flow and you can't raise the booms without shutting off the pump. The MX100's and up were a lot better because I think they added a second pump to split up the hydraulic demand.
