North Central IL | We had this issue on an old planter. Would disengage half way then need a bar to finish. Went so far as to try grinding out the slot a little further back. Eventually the technician updated the software and it worked immediately, and continued to work halfway thru the next planting season. At that time it started to catch again. That planter got traded in the off-season. I was also wondering about the little cylinder orifice. But the updated software did make it work perfectly for a while! | |
