roaming | farmerdennis - 4/23/2014 04:45
Wanting to do variable rate 28% with Raven equipment on may applicator (John Blue pump). Is the pro 700 able to control the variable rate or do I need additional equipment in the cab?
Pro 700 can do VRT a couple of ways. You can add use a Raven replacement kit for Field-IQ, and unlock the Pro 700 for AFS AccuControl. Or you can use something like a 440, and connect it directly to the Pro 700 with a serial cable. VRT is possible either way |
