North End I-15 | Sears had a wet dry vac with a float and a 15 gallon tank .
when the water was close to the motor the float would shut the suction down .
But...... mine is old , as in 15 years ? It still works great . Can remove the head and use it as a leaf blower .
Also have a Rainbow Vac with an extended tank . Will suck up water real good but has no safety shut down for the suction. Have to keep an eye on the clear canister . | |
