Posted 4/20/2014 09:04 (#3826516 - in reply to #3826061) Subject: RE: Plumbing lift assist into 3pt on JD 8000
We use the auto headland control to down shift, lift planter, markers and lift assist, all in different hydraulic remotes. Is that an option for you? If it is, then you can control the timing and speed and still only push one button to lift and turn around.
