Middlesex County, Ontario | Double check to make sure the distance from rear axle to antenna is right, both the inches and the before/after button. And double check the T2 orientation setting (plug facing back, forwards, or down. Those are easy settings to accidentally screw up.
Does it seem like it steers too slow? It steers towards the line, and when it gets on the line it takes way too long to steer straight and it kicks out? Decrease the angle per turn. Keep playing with it until it will somewhat hold a line.
Once it somewhat holds a line, start playing with the aggressiveness setting. Turn the aggressiveness down if it is doing tight s turns, turn it up if it is doing slow weaves.
Angle per turn and aggressiveness are the same thing really. Angle per turn is to get you in the ballpark and aggressiveness is to fine tune. |
