SD | 1. Singulator could be wore out. When they wear, more of the lobes cover the disk hole so you can increase vacuum for awhile, but usually end up needing new singulators.
2. Make sure everything spins freely (disk tension-electric drives aren't catching)
3. Could be a cracked seal or warped lid. Seals usually start cracking the worst at sharp bends.
4. Always use eflow. It is amazing how much a little talc and graphite improves any seed meter.
Edited by Rabbitfarmer 4/20/2014 07:30
