Woodham, Ontario | I used a cable from Deere that plugged into the corner post and then it had a radar plug and a power plug. Worked very well with a 7930 and 350 monitor.
First step is to make sure the tractor sees the radar. On the armrest display you should have a performance monitor. On the page where you can change what to display, you should be able to pick wheel speed, GPS speed and radar speed. Make sure they all work.
On the 2600 you may be able to do the same thing if it displays a performance monitor. On my 7230Rs it does not.
If you know the tractor is showing radar speed on the tractor's armrest display and/or the 2600, then I would try the monitor in a different tractor.
If the tractor does not see the radar speed, then you have to resolve that first. try a calibration on the armrest display.
Is the tractor new to you? | |
