Posted 4/17/2014 16:38 (#3822073 - in reply to #3822017) Subject: RE: JD 8400 ez steer
Oxford County, ON
They are nowhere near the same. You need bracket #53059-28 for your tractor. The picture below is our 7930, but they use the same bracket. You need to notch out a piece of plastic on the steering column to catch the bolts (instructions come with). An hour job at most.
