Posted 4/17/2014 12:01 (#3821819 - in reply to #3821635) Subject: RE: 8760 4wd
NESD
Make sure it has good tires, could cost a lot to put them on. It's not fun fixing hoses or oil leaks cause of the tight spaces so look for any before you buy. If your used to a newer style power shift with the little clicker you will not be impressed when you have to shift this tractor.
