Posted 4/11/2014 22:02 (#3810549 - in reply to #3810496) Subject: RE: JD 4455 top 2 rear field lights don't work
Hardin County, IA
X2 on the dimmer. If that doesn't fix it I would pull off the cover on the floor and check the plug going into the dimmer as well as the dimmer switch itself. Good luck!
Landon
